Nest Thermostat E Screen Replacement
  1. Nest Thermostat E Screen Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the base display off of the baseplate using an iFixit opening tool.
  4. Nest Thermostat E Screen Replacement, Dial: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
    • The two smaller screws go around the pin connector and the two larger screws go by the outside bezel.
    • Grab the pin connector and pull up to remove the thermostat backplate from the thermostat.
  5. Nest Thermostat E Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws.
  6. Nest Thermostat E Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the orange tab with tweezers and gently pull the ribbon cable directly away from the motherboard.
  7. Nest Thermostat E Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the display over and the battery casing will fall from the base.
  8. Nest Thermostat E Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws.
  9. Nest Thermostat E Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Thermostat E Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push out the display from the dial.
    • You might have to twist slightly.
    • Do not apply too much force which might cause the Nest Thermostat E screen to break.
    • You might hear a pop which signifies that the display came out of the display holder.
  10. Nest Thermostat E Screen Replacement, Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the screen.
Matthew Spector
crwdns2935283:003/01/23crwdne2935283:0
182 crwdns2915208:0crwdne2915208:0
University of Delaware, Team 11-6, McGuire Spring 2023 crwdns2935289:0University of Delaware, Team 11-6, McGuire Spring 2023crwdne2935289:0
UD-MCGUIRE-S23S11G6
crwdns2942667:0crwdne2942667:0 603
