Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
Remove the base plate and base display.
Pry the base display off of the baseplate using an iFixit opening tool.
Remove the four 6 mm screws using a Phillips #0 screwdriver.
Grab the pin connector and pull up to remove the thermostat backplate from the thermostat.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Grasp the orange tab with tweezers and gently pull the ribbon cable directly away from the motherboard.
Flip the display over and the battery casing will fall from the base.
