Nest Thermostat E Base Plate Replacement
  1. Nest Thermostat E Base Plate Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Base Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Base Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the base display off of the baseplate using an iFixit opening tool.
Andrew Ahlborn
crwdns2935283:002/27/23crwdne2935283:0
368 crwdns2915208:0crwdne2915208:0
University of Delaware, Team 11-6, McGuire Spring 2023 crwdns2935289:0University of Delaware, Team 11-6, McGuire Spring 2023crwdne2935289:0
UD-MCGUIRE-S23S11G6
Any recommendations on where to get 2nd and 3rd gen base plates. Both burned by lightning...
elippert - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 881
