Nest Learning Thermostat 3rd Generation Stuck On
  1. Nest Learning Thermostat 3rd Generation Stuck On, The Problem: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The existing thermostat was a two-wire installation using only R and W wires. To turn heat on, it connected R (24VAC power) to W (heating).
    • The Nest Thermostat has an internal battery that needs to be charged. If only two wires are connected it steals power from these lines. For some installations, it doesn't draw enough current to turn the heater on. Unfortunately, in my installation it draws too much current.
    • The Nest Base also uses power and steals it from two-wire installations. In my case, simply plugging in the base WITHOUT THE THERMOSTAT was enough to activate the heater.
    • I had thought the Nest Base was passive and simply connected wires together. But this is NOT the case. It has a power supply, and integrated circuits, so it requires power too.
    • This meant the heater was always running even when the Nest Thermostat said it was not.
  2. Nest Learning Thermostat 3rd Generation Stuck On, The Solution: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The solution is to add a C wire, also called a common or ground wire.
    • The Nest Thermostat and Nest Base can use power between R and C and not affect the W (heating) wire.
    • Fortunately, in my installation, the wire used actually had three conductors. So I just had to strip and connect the third wire.
    • Also fortunately, the Caleffi ZSR-106 has a terminal for C, it just wasn't wired up. So it was a simple matter to strip and connect the third wire on this side too.
    • In searching for a solution to my problem, I came across a few other issues:
    • In a two-wire installation, if the heater never turns on (eg. during the summer), the battery in the Nest Thermostat can go flat. So the Nest Thermostat will TURN ON THE HEAT, just to charge the battery.
    • This problem is also solved with a three-wire installation (adding a C wire).
    • Another problem might occur if you try to put too many Nest Thermostats on the same power transformer. The Nest Themostat uses a lot of power when it is charging its battery, so this adds up. I didn't have this problem, so I can't speak to it.
    • I only tried this with a 3rd generation Nest Thermostat. I expect other versions are similar, but I haven't tried them.
Alan Nishioka
crwdns2935283:007/17/11crwdne2935283:0
3 525 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 8,544
