Nest Learning Thermostat 2nd Generation Battery Replacement
Dustinluckenbill
crwdns2944107:0crwdnd2944107:0Dustinluckenbillcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:07crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Ndz 16, 2024crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
Replacing the battery on your Nest couldn't be easier. Removing 4 screws gets you into the Nest's display and the battery comes right out. The only tools required are tweezers and a Phillips #0 screwdriver.
crwdns2944105:0crwdne2944105:0
  1. Nest Learning Thermostat 2nd Generation Battery Replacement, Removal from Wall: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Learning Thermostat 2nd Generation Battery Replacement, Removal from Wall: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation Battery Replacement, Open Display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove the back of the display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Learning Thermostat 2nd Generation Battery Replacement, Remove the back of the display: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
    I pinched the connector and it will not pull out
    Robert Zelak - crwdns2934203:0crwdne2934203:0
    I’m my case, the white backplate cannot be pulled until it is turned about 1cm counterclockwise to disengage the brackets that hold to the internal plate. To do this, yo need to hold the front of the Nest with the metal frame (so the it doesn’t turn), while turning the backplate.
    Alberto Lazaro - crwdns2934203:0crwdne2934203:0
    And in my case, there are only 2 screws (in the 9 and 3 o’clock positions) and not 4 as shown in the photo.
    Alberto Lazaro -
  4. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
    How do you reattached the ribbon back to the motherboard ??
    alexehler - crwdns2934203:0crwdne2934203:0
  5. Nest Learning Thermostat 2nd Generation Battery Replacement, Lift battery from the base: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Learning Thermostat 2nd Generation Battery Replacement, Lift battery from the base: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the battery from the motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the battery from the motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
    Where do you buy the battery?
    Robert - crwdns2934203:0crwdne2934203:0
    At least say the tipe of battery that's needed.
    Pedro Sanchez - crwdns2934203:0crwdne2934203:0
    I just ordered the battery model specified. When it arrived, I realized it doesn’t have the same specs as the battery that comes with the thermostat.
    The part listed (TL284443) is 3.7 VDC, but it is only is 380mAh (1.41 Wh) (if you zoom in on the image when you click “Buy”, you can see)
    You can clearly see in the tear-down that the battery that comes with the thermostat is 2.1 Wh.
    It might work as a replacement, but doesn’t have the same capacity.
    Gerry Beggs - crwdns2934203:0crwdne2934203:0
    Double check your own equip online or in the manual people.
    There are different generations of thermostats. How would this guy know which battery you need.
    Thanks for the directions.
    Helps a lot.
    LisaKK - crwdns2934203:0crwdne2934203:0
    To be fair, most people don’t know that there are different generations of the Nest Thermostat and clearly they didn’t read that this was for the 2nd generation Nest Thermostat. Probably should have been pointed out in the instructions more clearly for those folks. Then they wouldn’t have been so confused about the battery voltage differences.
    Resist - crwdns2934203:0crwdne2934203:0
    I am a 64 year old woman, I had the Nest next generation installed last year. So far it keeps telling me that the connection to my wi-Fi is not working and now it’s saying the battery is dead. I’ve gone through all the steps to re-connect to wi-fi to no avail. Could this be because the battery needs replacing?
    It’s 68 degrees in my house now and that’s thanks to my fireplace not this horrible device. I am going back to the regular thermostat, what a waste of hard earned money.
    Laura Rogers - crwdns2934203:0crwdne2934203:0
crwdns2935229:044crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Dustinluckenbill
crwdns2935283:009/23/14crwdne2935283:0
703 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-5, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 11-5, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S11G5
crwdns2947412:015crwdne2947412:0
It should be noted that doing this will void the warranty on your device. If you are having issues with the display battery you should call the tech support line and they will help you. Doing this risk damaging the device and making it to where they will not replace it if it is still under warranty.
Bob bobbado - crwdns2934203:0crwdne2934203:0
ON MY NEST WHEN YOU "pull 2"...IT WAS GLUED TO THE METAL TOP OP THE MOTHERBOARD UNDERNEATH...SO IF THIS IS THE CASE BE VERY CAREFUL AS YOU DISLODGE THE BATTERY ....ALSO THE PLUG FOR THE BATTERY WAS TAPED DOWN WITH AMBER COLORED TAPE WHICH I HAD TO REMOVE BEFORE I WAS ABLE TO UNPLUG THE BATTERY...I REPLACED THE TAPE WITH SOME SCOTCH TAPE AFTER REINSTALLING THE BATTERY...ALL IN ALL...GOO INSTRUCTIONS...A FIVE MINUTE FIX !!!
Andrew Jordan - crwdns2934203:0crwdne2934203:0
I also am having a time finding the replacement battery
Brian wilson -
I am having trouble locating a replacement battery. Any idea where to look?
Ron Temaat - crwdns2934203:0crwdne2934203:0
As of 12/28/17 this website has replacement batteries for $12 plus shipping:
www.batteryclerk.com
Here’s a direct link to the Gen1 battery page which has a link to the Gen2 battery page
http://www.batteryclerk.com/products/nes...
Ron Saritzky - crwdns2934203:0crwdne2934203:0
My Nest gen2 thermostat experiencing problems offline, low voltage etc … After extensive troubleshooting with tech support i was advised by tech support to replace my gen 2 thermostat. After purchasing a new gen 3 I disovered that the battery of my out of warranty gen 2 was not working properly. After installing a “C” wire I deduced that the battery was at fault. After replacing the battery and using the thermostat it works as intended. So when you are chasing a problem with nest thermostat and a resolution seems elusive Try the battery, the solution was much easier than the process of tracking it down. The battery would cheaper than the time I put in with tech support.
Danny Thompson - crwdns2934203:0crwdne2934203:0
I purchased two replacement batteries from Ifixit and replaced in two Nest thermostats. The installation was as simple as stated above, however neither one works. The thermostats just sit on the wall and blink Green. There was a card included that said discharge to 10% to ensure battery voltage is detected properly. Does anyone know what that is about? How does one discharge to 10%,. I suppose I could leave the unit off the wall for a week and see if that fixes it, but maybe there is an explanation here? Hard to believe both batteries are defective.
Jeffrey Weiss - crwdns2934203:0crwdne2934203:0
Wasn’t clear which way to put battery connection to motherboard—sideways or up and out? Whatever I did, I screwed up battery to motherboard; glad I had a new Nest E ordered. About $144 which avoids a lot of heartbreak.. My gen 2 did not have the colored pull tabs and the battery was well glued/taped and not as serviceable in the description
Frederick Winter - crwdns2934203:0crwdne2934203:0
This guide would be useful if it showed how to get the motherboard cable reattached. I couldn't see how to do it, and now I've crushed one of the pins on my 3rd Gen.
goldmahn - crwdns2934203:0crwdne2934203:0
One question. Why are all the aftermarket batteries for the Nest thermos. wh rating less (in some cases alot ) than the original 2.1wh battery.?
Anthony Capuano Jr - crwdns2934203:0crwdne2934203:0
At the nominal operating voltage of 3.7VDC (for my Nest Gen2 Learning Thermostat), the equivalent 2.1Wh battery is about 570mAh. Im looking on Amazon and can get a 900mAh battery, which calculates as 3.33Wh
David -
The original battery says 2.1 WH while most of these replacement batteries say 1.4 WH ... is that a problem?
Ronald C Fazar - crwdns2934203:0crwdne2934203:0
Does the new battery need to be charged before it can be used? My thermostat is blank after properly, installing the battery, I plugged it into the USB port, and the little green light on the nest is blinking, but the display is not lit up or working at all
Carla Minosh - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 138
crwdns2936753:030crwdne2936753:0 579
crwdns2942667:0crwdne2942667:0 175,153
