crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind.
Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers.
Remove the two 40mm screws from the base of the thermostat using a #0 Phillips screw driver.
Unsnap the base from the trim plate (if used) using a plastic opening tool.
Turn the base over.
Remove the four 6 mm screws from the back of the base using a #0 Phillips screwdriver.
Pry the base mother board open from the side using a plastic opening tool.
Pry the baseboard from the bottom using the flat end of a spudger.
crwdns2944067:08crwdne2944067:0
Would like to know where I can get just the base motherboard.
Where can we purchase replacement parts?
i want the baseboard.. where i can buy? pls help...
Yep, my base unit lasted exactly 8 days, then it shorted out. The furnace repairman said he has seen it a couple of times, the base unit can't handle the current needed by the furnace so it goes poof. Back to Honeywell...
No replacement parts from Nest, my base unit died and I have perfectly working thermostat but am forced to buy a new one cause I can't get the base unit on its own.
