Nest Dropcam Pro Motherboard Replacement
  1. Nest Dropcam Pro Motherboard Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
    Where do you purchase drop cam pro motherboard?
    Geo - crwdns2934203:0crwdne2934203:0
  4. Nest Dropcam Pro Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
    may i know what those chips are?
    Thanks.
    julian - crwdns2934203:0crwdne2934203:0
  6. Nest Dropcam Pro Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
David Foens
crwdns2935283:009/03/15crwdne2935283:0
893 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-4, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 15-4, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S15G4
crwdns2947412:07crwdne2947412:0
where we can get the mother board to replace
fercervantes - crwdns2934203:0crwdne2934203:0
I need this too
kundimberi -
Where can I get the motherboard
xtogamba - crwdns2934203:0crwdne2934203:0
Can't find it either. Silly to write an entire article for credit if parts arent actually available.
Bruce Weissman - crwdns2934203:0crwdne2934203:0
searched for the MB online?? Why no mention of where to get it??
anonymous 6761 - crwdns2934203:0crwdne2934203:0
Source for Dropcam Pro motherboard? Are these actually available anywhere?
Robert the lessor - crwdns2934203:0crwdne2934203:0
I agree where is the source for Dropcam Pro motherboard? Are these actually available anywhere? @Davidfoenes @yvaneck @geoff @julianw @xtogamba
mendstern - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,866
