This guide is used to replace the motherboard of the Nest Dropcam Pro if yours has stopped working. Make sure the device is unplugged before opening.
Press in the mounting clips on each side of the case to remove the camera from the mount.
Using a Philips #0 screwdriver, remove the four 3 mm screws.
Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
Pull the motherboard away from the back case.
Unplug the red and black cable connecting the motherboard to the back case.
Using a Philips #0 screwdriver, remove the four 2 mm screws.
Lift the lens and LED assembly away from the motherboard.
Unplug the yellow and white cable from the motherboard.
crwdns2947412:07crwdne2947412:0
where we can get the mother board to replace
I need this too
Where can I get the motherboard
Can't find it either. Silly to write an entire article for credit if parts arent actually available.
searched for the MB online?? Why no mention of where to get it??
Source for Dropcam Pro motherboard? Are these actually available anywhere?
