Nest Dropcam Pro Micro-USB Port Replacement
  1. Nest Dropcam Pro Micro-USB Port Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
    • Lift the Micro-USB port away from the motherboard.
David Foens
crwdns2935283:009/03/15crwdne2935283:0
893 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-4, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 15-4, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S15G4
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Kreschendalyn Backus - crwdns2934203:0crwdne2934203:0
Did it work for you?
Michael Candy -
Where can you order the micro-usb charge port for this cam?
Danny Acevedo - crwdns2934203:0crwdne2934203:0
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
https://bit.ly/2Kg01z6
Debbie - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,867
