This guide is needed to replace the Micro-USB port if the Nest Dropcam Pro is plugged in but not receiving power. Make sure the device is unplugged before opening.
Press in the mounting clips on each side of the case to remove the camera from the mount.
Using a Philips #0 screwdriver, remove the four 3 mm screws.
Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
Pull the motherboard away from the back case.
Unplug the red and black cable connecting the motherboard to the back case.
Using a Philips #0 screwdriver, remove the four 2 mm screws.
Lift the lens and LED assembly away from the motherboard.
Unplug the yellow and white cable from the motherboard.
Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
Lift the Micro-USB port away from the motherboard.
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Did it work for you?
Where can you order the micro-usb charge port for this cam?
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
