Nest Dropcam Pro Camera Lens Replacement
  1. Nest Dropcam Pro Camera Lens Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
    Where do you purchase drop cam pro motherboard?
    Geo - crwdns2934203:0crwdne2934203:0
  4. Nest Dropcam Pro Camera Lens Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
    may i know what those chips are?
    Thanks.
    julian - crwdns2934203:0crwdne2934203:0
  6. Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement, Camera Lens: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  9. Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the paper seal holding the Lens and LEDs together.
    • Disconnect the red and white wire from the bottom board.
  10. Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the foam cover to reveal a second screw underneath.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws.
  11. Nest Dropcam Pro Camera Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the screws gone, lift the camera lens away from the remaining components.
David Foens
crwdns2935283:009/03/15crwdne2935283:0
893 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-4, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 15-4, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S15G4
Where do you get replacement lens?
Jim Fischer - crwdns2934203:0crwdne2934203:0
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,848
