Nest Cam Outdoor S Battery Replacement
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Cam Outdoor S Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Cam Outdoor S Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
    Not enough detail to finish the dismantling although it was a bare start
    David Ewing - crwdns2934203:0crwdne2934203:0
Phelix Gaudette
crwdns2935283:010/28/21crwdne2935283:0
275 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 crwdns2935289:0UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021crwdne2935289:0
UMASSD-GULBRANDSEN-F21S4G6
Do you have the P/N of the battery??
Richard K Yabuki - crwdns2934203:0crwdne2934203:0
Where to buy a replacement battery?
Ted McKenna - crwdns2934203:0crwdne2934203:0
I believe the battery model is GS24 (3.65V, 600 mAh/21.9Wh).
I also saw this on the battery
GPN: G823-00181-01
Dung Huynh - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 130
crwdns2942667:0crwdne2942667:0 9,082
