Nespresso/Nescafé Dolce Gusto water pump functionality check
  1. Nespresso/Nescafé Dolce Gusto water pump functionality check, Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check, Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check, Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Picture 1: Water pump from the Nescafe Nespresso, common and similar to the majority of models, thus the checking/testing using this pump can be used for any similar models.
    • Picture 2: Parameters for the water pump, indicated by the manufacturer. Please pay extra attention to the required voltage as well as the work time and rest time for the pump indicated by the manufacturer, in addition to the maximum initial water temperature (although this last one is not critical), can withstand a higher temperature.
    • Picture 3: Protection thermostat from the water pump which is connected in series to the pump. It is also intertwined with one of the feeding cables.
  2. Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Water pump coil test, using a multimeter in the ohms scale, from 10-20 Mohms, depending on what the multimeter has.
    • For a 230V pump the measurments in ohms of direct current between Red/Black cables must be between 2 and 8 Mohms. In this picture 7,92 Mohms are being measured.
  3. Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reverse polarity measurement of the coil. In this black/red polarization, the multimeter should read "1" with no continuity. This is because the coil has an internal diode which prevents current from flowing inversely. This would be a false positive for a broken coil, but when switching around the polarization it reads perfectly fine.
  4. Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the tests using an automatic/autoscale multimeter. Yous will find that the readings might vary wildly.
    • Picture 2: The measurement shown is 2,729 Mohms
  5. Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pictures on detail of the measurement
  6. Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • By changing direction of the probes we can see that, similarly to what happened in the first multimeter, we still do not get the measurement AUTO = open circuit.
  7. Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso/Nescafé Dolce Gusto water pump functionality check: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The multimeter reading has given us the correct measurement. Supplying the pump motor directly from mains power will not be necessary, but if you want to double-check it, you can try it.
    • We need a cable with the correct adapter for our location and 2 "FASTON" connectors.
    • When the cable is plugged into mains and the motor, the pump should vibrate and make the same noise that we hear when making a coffee to indicate that the water pump is functioning. Keep in mind that since the pump is not connected to water, it will may overheat and burn out if you run the test for longer than 5-8 seconds.
    • With all of this done, we have ensured that the pump is in working order.
This guide only goes over how to check that the water pump works, assuming the machine has already been taken apart. Applicable to water pumps from similar coffee machines such as Nespresso/Nescafe Dolce Gusto Piccolo machines.
crwdns2934873:0crwdne2934873:0
es en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Carlos López (España - Spain)
crwdns2935283:007/01/15crwdne2935283:0
75 686 crwdns2915208:0crwdne2915208:0
crwdns2935297:0246crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Hola! como se si el problema es la bomba de agua? mi maquina prende todas las luces pero no hace ningun ruido y no responde a ningun comando... se me tildo en el proceso de descalcificacion, y no volvio a arrancar...
ANDREA DOMENINO - crwdns2934203:0crwdne2934203:0
Me pasó lo mismo que a Andrea. Alguna solución?
air cac -
En tu caso Andrea casi seguro no es la bomba, se habra quedado en el proceso de descalcificar has de revisar en el manual como sale de esa funcion, sino la otra opcion para saber si es averia de la bomba implica desmontar la maquina y medir la bomba.
Carlos López (España - Spain) - crwdns2934203:0crwdne2934203:0
Buenas mi maquina de cafe capsulas la prendo y me tira el agua sola que puede ser
tomatito Pereira - crwdns2934203:0crwdne2934203:0
Solo hellegado a esa parte una vez, demsontando entero el prensacapsula, en la parte mas proxima al tubo lleva una especie de valvula antiretorno, esa zona se ensucia de cal, no es precisamente facil de desmontar, en la que lo vi es porque la desguazaba, antes de desmontar te aconsjo hagas una descalcificacion con algun producto descalcificador del supermercado para ver si te evitas desmontar
No descalcifica intenta iniciar el proceso y se pasa a una luz roja fija, inicialmente luz mitad roja mitad verde, alguin me puede ayudar?
Cindy - crwdns2934203:0crwdne2934203:0
¿tienes o puedes aportar una foto de la placa electronica? sustituye el condensador grande rectangular de la placa electronica
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 4,043
