The chosen product here is the Nespresso Pixie. This repair guide will give you all of the necessary tools in order to replace the internal diffuser plate. The guide will take approximately 45 minutes to an hour depending on past experience. At this end of this guide, you will be able to completely take apart this machine in order to cleanse or replace the internal diffuser plate. The most challenging issue you have will be pulling with enough force to pull it apart without breaking it.
Unplug the machine from any outlets.
Remove the water tank by pressing the top button and pulling outwards.
Use a Torx T5 screwdriver to detach the lever of the machine on both sides.
Remove the drip tray using your hand.
Use your hand to remove the black drip tray grill behind the drip tray.
Use a Torx T4 screwdriver to unscrew each screw on the faceplates.
Remove the faceplate using a metal spudger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Locate the two springs in each top right corner and use a set of tweezers to remove them.
Take off the white plastic bits using a metal spudger.
Remove the clear plastic bits using a metal spudger.
Wrong way to remove it.
There is a clips on the other side. Remove connector first
Use your hands to remove the cables that give power to the machine.
Use your hands to remove the water spout.
Seperate both halves of the machine using both a spudger and your hands.
Once you have unclipped the side at the top, middle of the side and base. You can push with a screw driver through the hole on the reverse side to help remove the plastic side.
Use your hands to pull out the first lever housing in the spot shown in the picture.
Pull the brewing mechanism apart from the remaining plastic barrier.
Once it is separated, pull off the other lever housing in the same way as was described in the previous step.
Use a spudger to unclip the clips holding the black case in place.
Pull the brewing chamber outwards from the machine and then pull it downwards to detach it.
Pry off the clips holding the inner white chamber in place in the machine.
Use a spudger to take off your diffuser plate.
Insert your new diffuser plate.
I’m sorry but this tutorial should be removed. You’ll just going to broke parts by following that.
