Nespresso Pixie Internal Diffuser Replacement
    1. Nespresso Pixie Internal Diffuser Replacement, Internal Diffuser: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unplug the machine from any outlets.
      • Remove the water tank by pressing the top button and pulling outwards.
      • Make sure there is no fluid left in any part of the machine.
    2. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Torx T5 screwdriver to detach the lever of the machine on both sides.
    3. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the drip tray using your hand.
    4. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your hand to remove the black drip tray grill behind the drip tray.
    5. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Torx T4 screwdriver to unscrew each screw on the faceplates.
      • Remove the faceplate using a metal spudger.
      • Be sure to start in both corners to separate the pieces.
    6. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the two springs in each top right corner and use a set of tweezers to remove them.
      • Be sure to set the machine in an enclosed container when this is done so as to not to lose the springs.
    7. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Take off the white plastic bits using a metal spudger.
    8. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the clear plastic bits using a metal spudger.
      • Be sure to pull it out using the hole in which it is indented.
    9. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your hands to remove the cables that give power to the machine.
    10. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your hands to remove the water spout.
    11. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Seperate both halves of the machine using both a spudger and your hands.
      • Once you have unclipped the side at the top, middle of the side and base. You can push with a screw driver through the hole on the reverse side to help remove the plastic side.
      • Be sure to take your time and start in the middle. Note that it is incredibly well secured.
    12. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your hands to pull out the first lever housing in the spot shown in the picture.
    13. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the brewing mechanism apart from the remaining plastic barrier.
      • Once it is separated, pull off the other lever housing in the same way as was described in the previous step.
    14. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to unclip the clips holding the black case in place.
      • Pull the brewing chamber outwards from the machine and then pull it downwards to detach it.
    15. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry off the clips holding the inner white chamber in place in the machine.
    16. Nespresso Pixie Internal Diffuser Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to take off your diffuser plate.
      • Insert your new diffuser plate.
Drew
crwdns2935283:011/05/23crwdne2935283:0
281 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 crwdns2935289:0UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023crwdne2935289:0
UMASSD-GULBRANDSEN-F23S2G2
crwdns2935297:036crwdne2935297:0
I’m sorry but this tutorial should be removed. You’ll just going to broke parts by following that.
biorn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 257
crwdns2942667:0crwdne2942667:0 5,891
