There are some situations where the plunger may stop functioning. This will result the loss of pressure needed to propel the Nerf darts out of the crossbow. This guide will demonstrate how to evaluate this type of problem and offer a way to fix it.
Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
Separate each part of the Nerf crossbow.
Check to make sure the plunger is intact and has the the rubber stopper at the end of it.
Also make sure the spring is intact and is not bent.
Make sure that plunger is reattached to the cocking mechanism.
Check chamber to make sure that there are no holes or cracks.
