Nerf Recon CS-6 Plunger Replacement
  1. Nerf Recon CS-6 Plunger Replacement, Remove Magazine: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Nerf Recon CS-6 Plunger Replacement, Remove Visible Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Nerf Recon CS-6 Plunger Replacement, Remove Hidden Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf Recon CS-6 Plunger Replacement, Remove Hidden Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Nerf Recon CS-6 Plunger Replacement, Remove Plunger Cap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Nerf Recon CS-6 Plunger Replacement, Remove Slide Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Nerf Recon CS-6 Plunger Replacement, Split the Gun in Half: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf Recon CS-6 Plunger Replacement, Split the Gun in Half: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
  7. Nerf Recon CS-6 Plunger Replacement, Remove Spring: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf Recon CS-6 Plunger Replacement, Remove Spring: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the spring out the back of the gun.
  8. Nerf Recon CS-6 Plunger Replacement, Removing Plunger Guide: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the plunger guide straight up out of the gun.
  9. Nerf Recon CS-6 Plunger Replacement, Remove Plunger: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the plunger out the back of the gun off of the inner piece.
  10. Nerf Recon CS-6 Plunger Replacement, Remove  Other Half of Plunger: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the remaining half of the plunger out the back of the gun.
Asad Qureshi
crwdns2935283:010/22/14crwdne2935283:0
595 crwdns2915208:0crwdne2915208:0
Baylor, Team 8-14, Williams Fall 2014 crwdns2935289:0Baylor, Team 8-14, Williams Fall 2014crwdne2935289:0
BU-WILLIAMS-F14S8G14
Do you know anywhere that you can buy a replacement plunger? Thanks
Angela Hirschi - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,931
