The plunger works with the main spring to launch the dart. The o-ring creates a tight seal to stop air from leaking out when the main spring is compressed. This allows for a more powerful shot.
Pull slide back.
Pull backwards on release buttons and slide magazine out.
Push slide back forward and pull trigger.
Use the Phillips #0 Screwdriver to remove these 9 screws.
All screws marked in red are 9.6 mm Phillips #0 screws.
Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
Pull slide back to reveal more screws.
Remove these 2 screws.
Push slide forward.
Pull trigger to release compression of the main spring.
Screws are 9.6 mm Phillips #0.
Lost the trigger spring. What spec of spring can I replace it with?
Remove the screws on the plunger cap.
Tug the plunger cap off.
Remove the 2 screws on the slide.
Pull the gun apart at the middle seam.
Pay attention to the orientation of the tabs on the compression tube. The tabs fit into grooves on the side of the gun. This tripped me up.
Pull the spring out the back of the gun.
Lift the plunger guide straight up out of the gun.
Pull the plunger out the back of the gun off of the inner piece.
Pull the remaining half of the plunger out the back of the gun.
Hi, do you know where is the place that I can purchase the plunger?
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to lift the O-Ring out of groove.
Replace with new O-Ring.
Optional: add a small amount of a lubricant safe for the O-Ring such as petroleum jelly.
Ace Hardware 1/16x13/16x1/16 #37 R-80 O-Ring fits
My priming bar is stuck how do I fix this?
Ethan - crwdns2934203:0crwdne2934203:0
