Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement
  1. Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement, Plunger Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement, Plunger Spring: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 12 screws with Phillips #1 screwdriver. Keep them in a small container to prevent loss.
    • It is recommended to use a Phillips #0 screwdriver to remove this screw. A Phillips #1 screwdriver can be used, but it may damage the screw, and a new screw will be required.
    • Carefully pry the primer off.
    • The nerf Cycloneshock uses 8 10mm, 3 12mm, and 1 8mm screw
  2. Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry open the shell. If it does not come off easily, double check that all screws are fully removed.
  3. Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the trigger and hook, then carefully remove them.
    • For this step you don't need screwdriver.
  4. Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the plunger mechanism towards yourself, then carefully remove the plunger.
  5. Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the screw on the plunger.
    • Use a Phillips #1 Screwdriver to unscrew it.
    • Slide the old plunger spring off the plunger rod. If the spring is stuck, gently wiggle it free, and make sure you do not damage surrounding components.
  6. Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the new spring onto the plunger rod.
    • Put top back on aligning groves with plunger.
    • Compress the spring makes it easier.
  7. Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Mega Cycloneshock Plunger Spring Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the plunger assembly back in its correct position.
    • Place back of plunger in grove.
    • Align all internal components properly before closing the shell.
    • Use a Phillips screwdriver to reinstall all screws.
    • Load a Nerf and test fire to check functionality.
By following this guide, you have successfully replaced the plunger spring in your Nerf N-Strike Mega Cycloneshock. This simple upgrade can restore and ensure stronger and more consistent shots, and if you experience any issues, double check the alignment of internal components.
Thomas Wong
crwdns2935283:001/13/24crwdne2935283:0
352 crwdns2915208:0crwdne2915208:0
York University, Team 4-5, Woodhouse Winter 2025 crwdns2935289:0York University, Team 4-5, Woodhouse Winter 2025crwdne2935289:0
YORK-WOODHOUSE-W25S4G5
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 206
