Nerf N-Strike Firestrike O-Ring and Plunger Replacement
  1. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Remove battery cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Blaster Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Without removing the barrel assembly, tilt it slightly upwards.
    • Slide the plunger out from the air chamber.
Clovis Jahan
crwdns2935283:004/23/15crwdne2935283:0
200 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-6, Amido Spring 2015 crwdns2935289:0Cal Poly, Team 15-6, Amido Spring 2015crwdne2935289:0
CPSU-AMIDO-S15S15G6
crwdns2942667:0crwdne2942667:0 5,027
