Nerf N-Strike Firestrike LED Replacement
  1. Nerf N-Strike Firestrike LED Replacement, Blaster Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  2. Nerf N-Strike Firestrike LED Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Firestrike LED Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  3. Nerf N-Strike Firestrike LED Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Firestrike LED Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  4. Nerf N-Strike Firestrike LED Replacement, Remove battery cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  5. Nerf N-Strike Firestrike LED Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Firestrike LED Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide out the two AAA batteries using your fingers.
  6. Nerf N-Strike Firestrike LED Replacement, Laser Trigger: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Firestrike LED Replacement, Laser Trigger: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
  7. Nerf N-Strike Firestrike LED Replacement, Laser Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
  8. Nerf N-Strike Firestrike LED Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Firestrike LED Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Firestrike LED Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
    • Slide the laser assembly out.
  9. Nerf N-Strike Firestrike LED Replacement, LED: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Firestrike LED Replacement, LED: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the clips holding the laser beam casing to the circuit board with your fingers. Slide off the casing revealing the LED.
  10. Nerf N-Strike Firestrike LED Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to heat up the two connections holding the LED to the circuit board. Remove the LED.
Hayes Kimball
crwdns2935283:004/19/15crwdne2935283:0
742 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-6, Amido Spring 2015 crwdns2935289:0Cal Poly, Team 15-6, Amido Spring 2015crwdne2935289:0
CPSU-AMIDO-S15S15G6
crwdns2942667:0crwdne2942667:0 3,179
