This guide will outline the steps to remove and replace your Nerf N-Strike Firestrike's batteries. You only need a #1 Phillips Screwdriver and your hands. This guide can be completed anywhere and in under five minutes.
Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
Slide out the two AAA batteries using your fingers.
loved it it is amazing :)
amazing loved it : )
Thanks a lot!!
Do we rlly need alkaline batteries
This should be step 1
Samuel Garcia - crwdns2934203:0crwdne2934203:0
