Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement
  1. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
  6. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Spring Piston Chamber: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Spring Piston Chamber: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, remove the outer parts of the blaster, starting with the top part of the cocking mechanism. Then remove the full cover itself.
  7. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the barrel and the front part of the blaster. The components should simply slide off.
  8. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw on the inside of the gun.
    • Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  9. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the trigger, the cocking holdback, and the air compressor chamber
  10. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the spring holding the air compressor together.
  11. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the spring air compressor component.
  12. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is the spring that controls the air compressor. If it is damaged you have found your problem. Replace this spring and the blaster should work.
Dylan Cooper Dalrymple
crwdns2935283:001/15/15crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-4, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 5-4, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S5G4
crwdns2935297:013crwdne2935297:0
mi nerf strongarm no dispara los dardos con la misma potencia que cuando la utilice por primera vez, dispara los dardos demasiado suave
juanestebanlopezcastrillon - crwdns2934203:0crwdne2934203:0
Maybe the problem is the dards.
Álvaro Sousa PT -
My nerf elite disruptor's drum some times working but sometimes notworkin
Skm - crwdns2934203:0crwdne2934203:0
what is the size of the spring?
JoseRafael - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 32,934
