Remove the outside cover of the Nerf gun (cover and charging slide, 12 Phillips #0 screws).
From the base, lift the action and the trigger.
Lift the Nerf dart cylinder and the firing mechanism (spring chamber).
Unscrew screws (2) from the cylinder rotator mechanism.
Remove the air plunger and the spring from inside the chamber.
Turn the spring counter-clockwise to free the spring. Be careful at the beginning and the end of the process.
Replace the spring.
The spring will be greasy. Don’t be alarmed. Be careful at the beginning and the end of the process because it is like getting a key ring on at the notches, particularly at the top of the chamber.
Return the plunger to the spring chamber.
Screw the cover back onto the cylinder rotator.
Place the spring chamber and the Nerf bullet cylinder back into the base.
Screw the trigger and the action back in. Swing the gray gun charging slide out when putting the action back in.
Secure the cover and the charging slide with the 12 screws.
crwdns2935229:05crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Where can I buy a replacement spring?
you can get a replacement or an upgrade spring at the website www.nfstrike.com
When I put it back together it did not work
My kid got sand in this blaster and i was tasked with fixing. i degreased the parts and used a plastic grease to re lube, but it was too thick for the plunger so the darts limped out the barrel. so i opened it up and used some fogging oil in there after cleaning it out. works a treat. The biggest problem was the little spring on the barrel.. I lost it 4 times, and the fifth it was gone. So i used a spring from a clicky pen and it works great now!
I opened it and some parts fell out and I don't know where they belong:
A small, orange plastic rectangle. About 12x8x2mm in diameter. One side has two ridges in the middle sticking up, the other side has 4 nobs on the corners and circle protrusion.
what is it, where does it belong?
