Nerf N-Strike Elite Strongarm Main Spring Replacement
  1. Nerf N-Strike Elite Strongarm Main Spring Replacement, Main Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the outside cover of the Nerf gun (cover and charging slide, 12 Phillips #0 screws).
  2. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the base, lift the action and the trigger.
  3. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the Nerf dart cylinder and the firing mechanism (spring chamber).
  4. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew screws (2) from the cylinder rotator mechanism.
  5. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the air plunger and the spring from inside the chamber.
  6. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the spring counter-clockwise to free the spring. Be careful at the beginning and the end of the process.
  7. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the spring.
    • The spring will be greasy. Don’t be alarmed. Be careful at the beginning and the end of the process because it is like getting a key ring on at the notches, particularly at the top of the chamber.
    • Tip: If dry, use a little vegetable oil on the O-ring before putting it back.
  8. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Return the plunger to the spring chamber.
  9. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw the cover back onto the cylinder rotator.
  10. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the spring chamber and the Nerf bullet cylinder back into the base.
  11. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw the trigger and the action back in. Swing the gray gun charging slide out when putting the action back in.
  12. Nerf N-Strike Elite Strongarm Main Spring Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Secure the cover and the charging slide with the 12 screws.
crwdns2935229:05crwdne2935229:0
Robert
crwdns2935283:003/18/15crwdne2935283:0
192 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Where can I buy a replacement spring?
mike580358 - crwdns2934203:0crwdne2934203:0
you can get a replacement or an upgrade spring at the website www.nfstrike.com
NEW CHANNEL -
When I put it back together it did not work
autisteck - crwdns2934203:0crwdne2934203:0
My kid got sand in this blaster and i was tasked with fixing. i degreased the parts and used a plastic grease to re lube, but it was too thick for the plunger so the darts limped out the barrel. so i opened it up and used some fogging oil in there after cleaning it out. works a treat. The biggest problem was the little spring on the barrel.. I lost it 4 times, and the fifth it was gone. So i used a spring from a clicky pen and it works great now!
tiderfish - crwdns2934203:0crwdne2934203:0
I opened it and some parts fell out and I don't know where they belong:
A small, orange plastic rectangle. About 12x8x2mm in diameter. One side has two ridges in the middle sticking up, the other side has 4 nobs on the corners and circle protrusion.
what is it, where does it belong?
knight blake - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 17,002
