This guide is going to show you how to take apart the blaster to reach the spring that is located in cocking mechanism of the Nerf.
Lay the Nerf Strongarm on its side, left side facing up.
Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
At this time, remove the blaster cover to reveal its internals.
Once the screws have been removed, lift the top half of the gun off.
Take care and try not to lose any smaller pieces as you open it up.
Locking tab for attachments.
what is a locking tab? and where do i see it? sorry my english is bad
its the front sight post
Remove the screw on the inside of the gun.
Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Remove the barrel from the blaster.
Remove the front component from the blaster.
Both components do not need any tools to be removed.
First, remove the trigger.
Then remove the cocking holdback.
Then remove the air compressor chamber.
Locate and remove the indicated screw.
This is the spring controlling the cocking mechanism. If the spring is damaged, replace it.
Where do I buy a new one
I was wondering the same thing
what are screw specifications?
Hi where do I buy that spring?
hi my spring is broken to and i was wondering where to buy a replacement spring for this nerf blaster
crwdns2935229:017crwdne2935229:0
crwdns2947412:021crwdne2947412:0
That screw holding the spring on the cocking mechanism, I accidently misplaced that, can you tell me what type of screw it is so I could buy a replacement.
Cheers :D
Where does the locking tab in step 5 go
on the top of the gun(Seeing from the position as if you're aiming)
Its only there for accesory so it still works if you don't return it
chanisco -
butt my spring was not damaged so whats wrong then?
The catch piece that catches the trigger slide broke when the kids dropped it while cocked. I tried gorrila gluing the very small platic nubs back on but they couldnt hold the spring pressure when cocked and broke again. Where can i buy parts?
What type of spring is it and where can I buy it because I stretched it too much and now it won't work
Me too, someone please answer this!
Where did the little, orange rectangle that appears in Step 5 come from and where do I put it back??
Ooops, okay, got it. I just saw the message above on this same topic!
thanks for writing this , it helps alot
Where could I get a replacement for the spring that pulls the cocking mechanism back?
I NEED TO KNOW WHERE TO GET A REPLACEMENT SPRING!!!!!!!!! Plz tell meh
Please any links or information on the replacement springs? You can’t complete this fix without new springs….
WHAT TYPE OF SCREW
•Locate and remove the indicated screw.
So I had the same problem I fixed the gun without the return spring. It isn’t worth Jack. I found with a side by side comparison of the disruptor and Strongarm that on the catch the disruptor has a better spring which fits on an internal notch. On the Strongarm you have to compress the catch spring a bit to fit it in.
Make sure the catch spring doesn’t clip over or it won’t work.
The piece of plastic that hoocks on to the plunger brock off so I cant find a spare part
What should I do?
Where can i buy a replacement spring for the priming handle on a disruptor
mine will slam fire, but not single fire. any tips?
What type of spring and screw do I need?
I have cocking holder parts
