This guide will show how to remove the barrel from the blaster. A good test to check if the barrel is stuck is shown in Step 6 (we suggest to do this before opening the blaster).
Lay the Nerf Strongarm on its side, left side facing up.
Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
At this time, remove the blaster cover to reveal its internals.
Once the screws have been removed, lift the top half of the gun off.
Take care and try not to lose any smaller pieces as you open it up.
Locking tab for attachments.
what is a locking tab? and where do i see it? sorry my english is bad
its the front sight post
Start by inspecting the barrel closer for broken components.
If the barrel fails to cooperate, continue onto the next steps.
Once the cover is off, the barrel component will be free and removable.
Once the barrel is removed, continue by removing the front shaft. This component is also independent of the blaster and does not require tools.
Look for any signs of debris or any damaged locations that may be causing the barrel to lock.
At this time, all components interacting with the barrel are removed.
Take this time to inspect the barrel for any signs of debris or damaged locations.
crwdns2935229:09crwdne2935229:0
crwdns2917034:0crwdne2917034:0
hi my barrel keeps ritating and is not fixed and does not stay aligned to the shooting point what shall i do
