Nerf N-Strike Elite Retaliator Spring Replacement
  1. Nerf N-Strike Elite Retaliator Spring Replacement, Case Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Retaliator Spring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Retaliator Spring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The spring may be compressed. If so, carefully release spring pressure before proceeding.
    • While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
crwdns2935229:011crwdne2935229:0
ericharman
crwdns2935283:003/02/16crwdne2935283:0
1,422 crwdns2915208:0crwdne2915208:0
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
Ryan Zhang - crwdns2934203:0crwdne2934203:0
can i use a nerf kronos spring
jordan - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 13,033
