Nerf N-Strike Elite Retaliator Case Disassembly
  1. Nerf N-Strike Elite Retaliator Case Disassembly, Case Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Case Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Case Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Case Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Retaliator Case Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Case Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Retaliator Case Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
crwdns2935229:028crwdne2935229:0
ericharman
crwdns2935283:003/02/16crwdne2935283:0
1,422 crwdns2915208:0crwdne2915208:0
crwdns2947412:015crwdne2947412:0
How do I clean the slider track?
devinwhaley - crwdns2934203:0crwdne2934203:0
you probably should not do that. i think its oily for a reason.
one smol birb -
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay -
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Pete Isaacs - crwdns2934203:0crwdne2934203:0
Leave the screws in the casing
Ewan Dority -
crwdns2936753:030crwdne2936753:0 211
crwdns2942667:0crwdne2942667:0 37,275
