Moving components in your blaster can be accessed by removing the outer casing. This guide shows how to access these inner components.
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
Remove the stock attachment point by removing the two 8mm Phillips head screws.
Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
crwdns2935229:029crwdne2935229:0
crwdns2947412:015crwdne2947412:0
How do I clean the slider track?
devinwhaley - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
you probably should not do that. i think its oily for a reason.
one smol birb - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Pete Isaacs - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Leave the screws in the casing
Ewan Dority - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
