Nerf N-Strike Elite Hail-Fire Motor Replacement
  1. Nerf N-Strike Elite Hail-Fire Motor Replacement, Left Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement, Left Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement, Left Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
    • Remove the two 9.0 mm Phillips screws securing the battery compartment.
    • Slide the battery compartment out.
  2. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 9.0 mm Phillips screws securing the trigger.
  3. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
    • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
  4. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
    • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
  5. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
  6. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
  7. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
    • Remove the single 7.0 mm Phillips screw below the barrel.
    • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
  8. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
  9. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 9.0 mm Phillips screws holding together the handle.
    • Remove the plastic cover of the handle.
  10. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
    • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
  11. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull one end of the handle away from the orange latch.
    • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
  12. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
    • Completely remove the left shell from the rest of the Nerf Gun.
  13. Nerf N-Strike Elite Hail-Fire Motor Replacement, Inner Plastic Components: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement, Inner Plastic Components: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement, Inner Plastic Components: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cartridge support.
  14. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the handle crank.
  15. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clear plastic barrel cover.
  16. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the firing pin.
    Not a pin, rather a plastic arm called the pusher
    Tribit Fan Opex ツ - crwdns2934203:0crwdne2934203:0
  17. Nerf N-Strike Elite Hail-Fire Motor Replacement, Motor: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement, Motor: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement, Motor: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your gun disassembled, locate the motor around the front portion of your gun as shown in Figure 1. Remove the two 9.0 mm Phillips screws securing the top shell of the motor casing.
  18. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top shell of the motor casing. This should reveal the inner workings of the motor.
  19. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the shell now removed, locate the motor and controlling circuit board. With your index finger and thumb, squeeze the holders shown in Figure 2 and pull upwards to release the motor module from the rest of the motor's casing. Your motor should be detached from the casing, as shown in Figure 3.
  20. Nerf N-Strike Elite Hail-Fire Motor Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the wiring from the motor by disconnecting the wires from the circuit board.
    So do you mean to cut the wires from their soldering place? B/c if that’s the case how do you fix/replace the motor? Thanks tho, this is great. For some reason one that I haven’t used really at all just stopped working after being in storage for a few years.
    theflash3 - crwdns2934203:0crwdne2934203:0
Chris
crwdns2935283:001/24/14crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-13, Regan Winter 2014 crwdns2935289:0Cal Poly, Team 13-13, Regan Winter 2014crwdne2935289:0
CPSU-REGAN-W14S13G13
Where do I get the motor from. I have a Nerf Demolisher 2 in 1 and I want to see if the place you buy it from has a motor for it.
Naman Singla - crwdns2934203:0crwdne2934203:0
If you are still looking for the motors, you could check if any of these work with your model http://www.containmentcrew.com/product-c... . They are motors used often by people adding power to their motorized blasters, however, you may need a more powerful battery such as a LiPo or Nihm H.
AwesomeAtomicAustin (Nope) -
How exactly does the handle come off of the gun because I am able to get up to the orange clips but I am unsure how exactly to remove them without damaging the gun
M0lten - crwdns2934203:0crwdne2934203:0
I have the whole gun apart, and I had dart jam. Now I am ready to reassemble, and the spring near the motor came off and I can't figure out where it goes or how to put it back properly… is there a picture or suggestion somewhere I'm not looking?
aellsbur - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 15,501
