Nerf N-Strike Deploy CS-6 Dart Tooth Replacement
  1. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement, Dart Tooth: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before releasing the device in Stealth mode, take out hidden screws as shown
    • Extend the device in Stealth Mode by pressing the button found on the handle.
  2. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out the screws from the pump.
    • Proceed to take out the other screws from the device to take off the cover.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws are out, you are able to take the cover piece off.
    • Proceed to remove the screws
    • Taking off those screws are vital in replacing the dart tooth.
  4. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully place cover piece above the device.
  5. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew as shown to aid in the replacement.
  6. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To take out the dart tooth, push the spring to the left.
    • The dart tooth should pop out with ease.
  7. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once pulled away from the device, take off the orange piece connected to the darth tooth
    • The piece can be identified with the spring.
  8. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You should now be able to pull apart the dart tooth from the device.
    • The piece that has been pulled away will have a type of lubrication. If this piece requires replacement, it will slide on with ease.
  9. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make any adjustment to the dart tooth as seen. May be pulled either up or down.
    • Place in the replacing piece in order to fix the darth tooth
  10. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place back on the orange piece with the spring to its original spot on the dart tooth.
    • While setting in the dart tooth back into place, the small spring on the yellow piece must be placed in its compartment as shown.
    • Place back cover pieces in order to secure the screws back into place.
Alec Hernandez
crwdns2935283:009/28/16crwdne2935283:0
132 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-5, Mathisen Fall 2016 crwdns2935289:0Eastern Washington University, Team 2-5, Mathisen Fall 2016crwdne2935289:0
EWU-MATHISEN-F16S2G5
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 3,179
