This guide will help you find and replace the motor spring.
Using the JIS #1 screwdriver, loosen the nine screws, holding the outer yellow shell in place
Remove the screw holding the battery compartment shut.
Lift off the inner blue casing
Lift off the blue casing, exposing the white motor spring compartment.
Loosen and remove the three screws holding the white compartment door shut.
Unsnap the white compartment into two pieces.
Remove the motor spring located inside the rotating barrel and replace.
