Nerf Dart Tag Furyfire Trigger Replacement
  1. Nerf Dart Tag Furyfire Trigger Replacement, Remove the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Trigger Replacement, Remove Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Trigger Replacement, Remove Black Cylinder: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Trigger Replacement, Remove Spring: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf Dart Tag Furyfire Trigger Replacement, Remove Spring: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Trigger Replacement, Remove Pump Handle: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Handle: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Trigger Replacement, Remove Attached Spring: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf Dart Tag Furyfire Trigger Replacement, Remove Attached Spring: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Trigger Replacement, Disengage White Piece: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Track: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Track: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hand, slide the track out of the gun by pulling it away form the device.
  10. Nerf Dart Tag Furyfire Trigger Replacement, Detach Black Piece from Trigger: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, detach the black piece from the trigger. You do not need to remove the black piece from the gun.
  11. Nerf Dart Tag Furyfire Trigger Replacement, Remove Trigger: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the black piece has been detached, the trigger can be lifted out of the device.
To reassemble your device, follow these instructions in reverse order. Ensure that the spring located behind the trigger is attached to the limb on the backside of the trigger.
Bradley Penrow
crwdns2935283:009/23/14crwdne2935283:0
37 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-2, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 11-2, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S11G2
crwdns2942667:0crwdne2942667:0 750
