Turn the Neo3DO face down so that the logo is facing toward you.
Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
Remove all the tape attached to the motherboard.
Pull out the black tabs using the plastic spudger.
Remove the wire belt from the socket.
Lift the black tab and then remove the wire belt.
Grip the side of the tab and pull upwards to remove it from the socket.
Remove the screws using the J0 head screwdriver.
Grip the active(red) wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
Repeat the same process to remove the neutral(black) wire.
Use the flat end of the plastic spudger to remove the motherboard and turn it underside-up.
Remove the plug from the motherboard socket.
Grip the wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
Remove the screws with a J000 screwdriver
Use the plastic removal tool to remove the plastic frame.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the plastic removal tool, lift the LED screen from the battery side, and use the tweezers to help lift the LED screen upwards.
Do you have a source for Neo3DO Digitizer replacement.
