Barrel clasps are on many pieces of jewelry, but there are only guides available on how to replace the clasp—not how to repair it. Taking a broken necklace to a jeweler or completely replacing the clasp can be expensive and time-consuming. To reduce waste and save broken jewelry, we will demonstrate how to fix a broken barrel clasp necklace while properly operating a soldering gun safely.
Locate the broken part of the ring that attaches through the back of the barrel clasp.
Bend the portion of the ring with needle nose pliers until the newly compact ring can be pushed through the barrel clasp and fit snug.
Plug in the electric soldering iron and set the solder temperature to the degrees that suits the melting point of both the soldering wire and the barrel clasp.
Solder the base of the barrel clasp where the metal ring fits in, intersecting the tips of the soldering gun and soldering wire.
Attach the barrel clasp necklace back together and hold each end of the necklace taught to test the solder strength.
