Neato XV-21 Battery Replacement/Removal
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
    This should be unnecessary. You should only need to remove the four screws from the battery doors. In this picture, the two lower-right screws are for one of the battery doors and the other is on the other side of the robot, under the demonstrator’s hands.
    John - crwdns2934203:0crwdne2934203:0
    It is EIGHT screws, not SEVEN.
    There are FOUR screws for the battery compartment panels (TWO for each).
    FOUR screws for the fan access panel.
    The panels are independent. There is no need to open the battery compartments to access the fan, nor vice versa.
    Fred - crwdns2934203:0crwdne2934203:0
  2. Neato XV-21 Battery Replacement/Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
Fernando Aguilar
crwdns2935283:009/25/17crwdne2935283:0
159 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S2-G3, Thompson Fall 2017 crwdns2935289:0University of North Texas, Team S2-G3, Thompson Fall 2017crwdne2935289:0
UNT-THOMPSON-F17S2G3
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,371
