Neato Botvac D8000 Wheel Replacement
  1. Neato Botvac D8000 Wheel Replacement, Brushes: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the vacuum on its back so the brushes are visible.
  2. Neato Botvac D8000 Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 10 mm screws with a Torx T10 screwdriver.
  3. Neato Botvac D8000 Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rotary brush simply by grabbing it firmly and pulling it off.
    • Once you have removed your rotary brush and 4 bolts, you can easy remove the brush guard.
  4. Neato Botvac D8000 Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the brush by simply pulling it out.
    • From there you can clean it or replace the brush with a new one.
  5. Neato Botvac D8000 Wheel Replacement, Top Face Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the rear bumper with both hands on either side.
  6. Neato Botvac D8000 Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly pull the bumper forward at a steady pace.
    • When pulling the bumper forward avoid being too rough because the bumper might break.
  7. Neato Botvac D8000 Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Looking from above, remove the two 11mm screws with a Torx T10 screwdriver.
  8. Neato Botvac D8000 Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
  9. Neato Botvac D8000 Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the clips, located in the back side, inward.
    • Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
    • When you lift the top cover be careful because the wires are thin and fragile.
  10. Neato Botvac D8000 Wheel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have carefully removed the wire clip; you can fully remove the top cover.
  11. Neato Botvac D8000 Wheel Replacement, Wheel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement, Wheel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement, Wheel: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the screws that mount the wheel extension to the Robot.
    • Unscrew the four 11mm screws indicated with a Torx T10 screwdriver to remove the frame.
    • Make sure to remove the metallic weight. However, this does not require the removal of any screws.
  12. Neato Botvac D8000 Wheel Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Delicately lift up the frame holding the laser. This will access the wheels.
    • Detach the wheel wires that are connected to the motherboard.
    • Once the wires are detached, the wheel are free from their casing.
  13. Neato Botvac D8000 Wheel Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac D8000 Wheel Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T15 screwdriver to remove the 32.5mm screw.
    • Finally, just hold and separate the wheel from its axle.
Ruth Lopez
crwdns2935283:003/22/18crwdne2935283:0
280 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S17-G6, Blackburne Spring 2018 crwdns2935289:0Sam Houston State, Team S17-G6, Blackburne Spring 2018crwdne2935289:0
SHSU-BLACKBURNE-S18S17G6
crwdns2942667:0crwdne2942667:0 3,774
