This guide will explain how to properly replace the display screen on the top of your Neato Botvac Connected.
Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
Remove the four screws lining the front roller using a TR10 Torx screwdriver.
Remove the black panel behind and in front of the roller.
Gently lift the roller by the right side to remove it.
Remove the two screws behind the front roller of the robot using a Phillips #2 screwdriver.
Remove the battery by lifting it out while pressing down on the wire clip inside the compartment.
Pull one side of the front bumper out and then forward toward you. Repeat on the other side to completely detach the front bumper.
Remove the eight screws from the underside of the Botvac using a TR10 Torx screwdriver.
Remove the additional two TR10 screws from the top of the Botvac.
Remove the dustbin.
Pry the clips on the front of the robot apart.
Unplug the beige connector with a spudger, working one side at a time until it comes unplugged.
Lay the top of the robot inside up.
Unplug the beige connector with a spudger. Be careful not to tear out any wires.
Remove the two screws from the screen using a TR10 Torx screwdriver.
Remove the screen from the vacuum.
