This guide will show you how to replace a faulty battery.
First, open the bin compartment and flip the switch to the off position.
Once you have done this, flip the robot over. Loosen the 2 screws, and lift the flap off
You will need to remove the 22.5mm bolts with a J1 Torx screwdriver.
Gently lift to remove battery cover.
Locate battery clip.
Press down on latch with thumb and slide clip back.
Remove the battery.
