Neato Botvac 65 Wheel Motors Replacement
  1. Neato Botvac 65 Wheel Motors Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device upside down.
    • Locate the two (2) 20mm screws on the batttery plate.
  2. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to loosen both screws.
  3. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery back plate to reveal the battery.
  4. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the current battery by pulling the connector from the base and pushing on the clip.
  5. Neato Botvac 65 Wheel Motors Replacement, Brush: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  6. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the screwdriver to take off the four (4) 10mm screws located near the brush which secure the plastic guard.
  7. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic brush guard.
    • Pull off the plastic covering the brush.
  8. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the brush to clean or replace.
  9. Neato Botvac 65 Wheel Motors Replacement, Top Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip device upside down.
    • Locate the six (6) screw connected to the top cover.
  10. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove eight (8) star screws using the T10 bit.
  11. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull off one side of the brush front cover, and then pull off the other.
  12. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip right side up and turn around.
    • FInd the two clips connecting the top cover to the body of the device.
  13. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the top cover gently.
    • Disconnect the connector from the motherboard to detach the top cover from the robot.
  14. Neato Botvac 65 Wheel Motors Replacement, Wheel Motors: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement, Wheel Motors: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement, Wheel Motors: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four (4) 10mm 'star' screws using the T10 bit from the base plate where the rotating infrared sensor is located.
    • Carefully place the sensor on or near the robot without pulling the wires out.
  15. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two (2) screws using the T10 bit that connects the plastic protector over the wheel motor.
    • Pull up on the metal weight to remove.
  16. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the botvac over being careful not to drop the IR sensor or cause damage to the wires.
    • Using a flat-head screw driver and a cloth for protection, press on the clips until they recede into the botvac.
  17. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the robot back over(right-side up).
    • Carefully remove the plastic cover that protects the motor.
  18. Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Neato Botvac 65 Wheel Motors Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the motor that you wish to replace.
    • Trace the wires that are connected to the motor back to the motherboard.
    • Disconnect the connector from the motherboard for the respective motor you're replacing.
Joseph Caton
crwdns2935283:002/15/17crwdne2935283:0
334 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team S2-G1, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S2G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,620
