In order to gain access to the components of the robot the top cover needs to be removed.
Flip the device upside down.
Locate the two (2) 20mm screws on the batttery plate.
Use the Phillips #1 screwdriver to loosen both screws.
Remove the battery back plate to reveal the battery.
Disconnect the current battery by pulling the connector from the base and pushing on the clip.
Use the screwdriver to take off the four (4) 10mm screws located near the brush which secure the plastic guard.
Remove the plastic brush guard.
Pull off the plastic covering the brush.
Flip device upside down.
Locate the six (6) screw connected to the top cover.
Remove eight (8) star screws using the T10 bit.
Pull off one side of the brush front cover, and then pull off the other.
Flip right side up and turn around.
FInd the two clips connecting the top cover to the body of the device.
Lift up on the top cover gently.
Disconnect the connector from the motherboard to detach the top cover from the robot.
