In this guide you will be able to replace the filter of the Neato Botvac Connected. The filter will need to be changed or cleaned once too much debris has built up causing the vacuum to no longer pick up dirt. The filter of the vacuum should be changed every few months to ensure the Neato Botvac is picking up debris properly. Following this guide comes after first following the guide to replace the battery to ensure safety.
Place the top of the Neato Botvac Connected against a flat surface.
Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
Using the spudger, remove the panel covering the battery.
Gently remove the connecting wires attached to the battery.
Using the spudger, gently remove the battery from the device.
Flip the cleaner around and locate the front panel.
Gently remove the front panel by opening it with a spudger.
Use the spudger to gently remove the paper filter.
