crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0NeXTstationcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. NeXTstation Teardown, NeXTstation Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown, NeXTstation Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown, NeXTstation Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The NeXTStation, this is a great addition to any computer collection.
  2. NeXTstation Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the NeXTStation around, and remove this screw:
    • Then, lift the top cover of the computer. This will reveal the guts.
    • The ports from left to right: SCSI2, Keyboard & Mouse, DSP Port, DB-19(MegaPixel Display), DB-9(Serial), RJ-45(Ethernet), Coaxial (10b2 Ethernet), Power
    • I find notes in everything!
  3. NeXTstation Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NeXTstation Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the hard drive:
    • The NeXTStation uses a 50-Pin SCSI Hard Drive up to 4GB.
    • Remove all of the cables from the logic board.
  4. NeXTstation Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Then remove this screw.
    • Once the screw is removed, pivot the drive up on a 45 Degree angle, then slide it out.
  5. NeXTstation Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Hard Drive & Caddy
  6. NeXTstation Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the floppy disk drive:
    • The NeXTStation uses a non-standard 2.88MB 3.5" floppy drive, though it uses the standard floppy connector.
    • Remove the floppy cable.
    • Then, remove this screw.
  7. NeXTstation Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Then, just like the hard drive, pivot the drive up 45 degrees, and pull it out.
  8. NeXTstation Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the fan:
    • Remove this connector.
    • Remove these screws.
    • Remove the fan.
  9. NeXTstation Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the logic board:
    • Remove the power supply connector. Just lift it straight up, and it should come free.
    • Remove this screw.
  10. NeXTstation Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the end of the logic board(away from the ports), and slide it away from the ports.
    • Now, set the board aside.
  11. NeXTstation Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power Supply:
    • Lift the power supply up, and out.
  12. NeXTstation Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Logic Board Overview:
    • The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for something made nearly 20 years ago.
    • The CPU: Motorola XC68040RC25
    • The Co-Procesor: MB610313
    • Motorola Chips
    • Intel Chips
    • AMD Chips (Intel and AMD In the same computer?)
    • Fujitsu Chips
  13. NeXTstation Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NeXTstation Teardown: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Made in the USA, you don't see this anymore.
    • The Serial #
    • Looks like my NeXTStation came from WilTel.
    • It is model # N1100
Chris Green
crwdns2935283:010/11/09crwdne2935283:0
38,086 crwdns2915208:0crwdne2915208:0
crwdns2935297:049crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0329crwdne2931471:0
crwdns2935297:01,452crwdne2935297:0
http://www.youtube.com/watch?v=jhfUKEu7s...
The Machine to Build the Machines:
Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Juddy - crwdns2934203:0crwdne2934203:0
crwdns2936937:0Juddycrwdne2936937:0
http://www.youtube.com/watch?v=jhfUKEu7s... The Machine to Build the Machines: Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Amazing!
Chris Green - crwdns2934203:0crwdne2934203:0
MB610313 - ICP (Integrated Channel Processor). Basically DMA on steroids for almost all of the main sub components of the system. I believe that the cube, or at least the 25Mhz 030/040 cubes, had two of these.
HotelCoralEssex - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 32,093
