Nanit Pro N301 Motherboard Replacement
  1. Nanit Pro N301 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nanit Pro N301 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nanit Pro N301 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the seam between the front and rear case.
    • Slide the opening pick around the perimeter of the camera until all of the retaining clips are released.
    • Separate the front and rear case.
  2. Nanit Pro N301 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4 mm T6 Torx screws from each corner of the circuit board.
    • Lift the circuit board out of the chassis.
  3. Nanit Pro N301 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the black wire's motherboard connection.
    • Soldering irons can cause burns and fires. Always solder/desolder in a well-ventilated workspace.
  4. Nanit Pro N301 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to gently lift the two additional circuit boards out of the housing.
  5. Nanit Pro N301 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery ribbon cable strip from the rear case.
    • Remove the motherboard.
Derek Maue
crwdns2935283:004/02/24crwdne2935283:0
151 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-1, Harley Spring 2024 crwdns2935289:0IUPUI, Team 3-1, Harley Spring 2024crwdne2935289:0
IUPUI-HARLEY-S24S3G1
Seems quite difficult to insert an opening pick into the seam between the front and back cover. Need more photos on how it is done. From the photos, it seems like some force is required to insert based on the marks left on the covers.
KevinS - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 357
