Nanit Pro N301 Camera Replacement
  1. Nanit Pro N301 Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nanit Pro N301 Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nanit Pro N301 Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the seam between the front and rear case.
    • Slide the opening pick around the perimeter of the camera until all of the retaining clips are released.
    • Separate the front and rear case.
  2. Nanit Pro N301 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4 mm T6 Torx screws from each corner of the circuit board.
    • Lift the circuit board out of the chassis.
  3. Nanit Pro N301 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nanit Pro N301 Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nanit Pro N301 Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber gasket around the camera.
  4. Nanit Pro N301 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the white camera connector from the circuit board.
    • Do not pull on the wires.
  5. Nanit Pro N301 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small Phillips screw that secures the camera.
  6. Nanit Pro N301 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nanit Pro N301 Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the filter from behind the camera lens.
  7. Nanit Pro N301 Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nanit Pro N301 Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T4 Torx screwdriver to remove the screws that secure the computer chip to the white plastic bracket.
  8. Nanit Pro N301 Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the circuit board away from the white plastic bracket.
  9. Nanit Pro N301 Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nanit Pro N301 Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two screws that secure the underside of the camera.
  10. Nanit Pro N301 Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the camera up and off the circuit board.
Ryan Maher
crwdns2935283:004/02/24crwdne2935283:0
211 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-1, Harley Spring 2024 crwdns2935289:0IUPUI, Team 3-1, Harley Spring 2024crwdne2935289:0
IUPUI-HARLEY-S24S3G1
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 151
crwdns2942667:0crwdne2942667:0 1,483
