Nail Clipper Reassembly
crwdns2942287:0crwdne2942287:0Have you ever brought nail clippers on a trip, only to find that they had fallen apart in your bag. Before buying a new pair, try fixing them with this simple guide. As long as you have all three necessary parts, if you follow these easy steps your nail clippers will be as good as new.
Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
The side of the rod with the notch should be inserted first.
Compress the body of the clippers to reveal the notch.
It is really hard for me to do this with one hand. help?
Me too it’s hard
me three i accidentally broke my nail clipper suddenly i have a another one
Rotate the rod until the notch opening faces away from the body.
This allows for easier completion of the following step.
Place the hole of the lever into the revealed rod notch.
Release the compressed nail clipper body to lock the lever into place.
Swivel the lever into its normal position, and test the nail clippers' functionality.
I accidentally broke my grandma’s nail clipper
but I fixed cuz of dis
Super vielen Dank es hat funktioniert
very helpful 10/10 guide, preciate u man
Tolle Anweisung, Dankeschön! Es klappte!
If you follow these steps, your nail clippers should be back to working order.
crwdns2935229:084crwdne2935229:0
crwdns2947412:030crwdne2947412:0
Thank you so much ! My fingers are arthritic and I was frustrated until I found your instructions.
Thank you. Knew it was simple! Love this website.
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
That's why it says reassembly 🤨
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
I used you steps, but whenever I try to rotate the handle so that I can clip my nails the handle just pops off again.
Albert E, the name of the website is “Nail Clipper Reassembly” you are not prooving a point. Its not dumb either because everyone else’s nail clippers work now. And the deffintion of repair is…
re·pair1
/rəˈper/
verb
1.
fix or mend (a thing suffering from damage or a fault). Or put something back together.
"faulty electrical appliances should be repaired by an electrician"
synonyms:mend, fix (up), put right, set right, restore, restore to working order, make as good as new, patch up, overhaul, service, renovate, recondition, rehabilitate, rebuild, reconstruct, refit, adjust, regulate; More
noun
Thank you!! I have been trying for weeks! Your pictures are awesome. I looked at the 1st one and I was good to go!
where would you find a replacement pin? Mine is bent beyond repair. mymothersblessing@yahoo.com.
its good idk what else to say
Perfect instructions!
Came home drunkk; stepped on my toenaiil clippers; googled how do I fix my toenail clippers; found your tutorial, and I fixed them!!!
I may not remember this tomorrow, but your tutorial was great. Thank you
Thank you so much, this really helped!
I fixed my clippers with your instructions 😊
Saved me from my hang nail. Thank you.
Like most things in life, when you get shown the proper way of doing things, it becomes simple. Thanks for the help.
Co-sign & I'm a visual-learner 100%
A. R. -
Amazing stuff, thank you!
Thanks! I was trying to figure out how to put them back together for the last 30 minutes, unsuccessfully. Only googling the question and finding your guide helped ❤️
thank u! this is a lifesaver.
So helpful, for some reason it felt liking trying to complete a Rubik’s cube before following this very handy guide!
This is too accurate! Lmao!!
A. R. -
thank god i found this, was going to buy a new one
I've had to reassemble my nail clippers a couple times before, but I can never remember the process. This is simple & efficient, thank you!!!
Thank you, it was easy, and much appreciated!
POP QUIZ: In which direction should the lever pull against the center rod when clipping? I have come to find that it ultimately DOES make a difference in the life of your clippers.. if you notice, the rod can be turned in the opposite direction and the force is no longer bending the "neck" or "notch" of the center rod "backward" or "open", but can be made to bend more "closed"... It in turn will extend the overall life of the clippers... (Ancient Chinese secret) ~ John Kipp
Thanks for this! I'd never had this happen before, and I was glad to find such straightforward instructions to repair my clippers!
thank you i had just broken my dads nail clippers so im so happy i found you thank you so much
its handy to have they say its nice\
Got tired of buying new nail clippers every time a pair broke. Thank you for this.
