Nabi Jr Screen Replacement
crwdns2944105:0crwdne2944105:0
Remove the red rubber case from the device. This should come off with ease.
Turn the device so the screen is facing away from you.
Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
Remove the device casing using a small plastic pry bar.
After loosening the back cover, remove it from the device so you can get at the innards.
Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
De-solder the grey wire from motherboard
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to peel off all yellow tape from the motherboard
Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
Use tweezers to pull the ribbon cable out of the locking tab's slot
Lift motherboard to separate it the from the case shell.
Remove the 6 screws that hold the screen in place
Remove the screen from the front casing
Separate the screen from the plastic casing.
Replace the old screen with the new screen
Do you know of anywhere I can send a nabi jr to have a cracked screen replaced?
Yes thank you for the information but where do we find a screen to replace this?
My navi jr is the nick jr edition and looks a bit different inside. I replaced the screen, as mentioned here but has to remove the outter glass-like screen that has the second smaller ribbonattach from the original screen, and put it on my screen because the new screen did not have that part. All buttons work, the screen looks perfect and vibrant, but the EFEN TOUCH Does not work!!! What did I do wrong? I attached all the ribbons properly!!!
