Nabi Jr Motherboard Replacement
  1. Nabi Jr Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
  6. Nabi Jr Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-solder the grey wire from motherboard
  7. Nabi Jr Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to peel off all yellow tape from the motherboard
    • Yellow tape is used in all locations where there is ribbon cable present.
  8. Nabi Jr Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nabi Jr Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
    • Pull black locking tabs up in opposite direction of ribbon cable to remove.
    • Use tweezers to pull the ribbon cable out of the locking tab's slot
  9. Nabi Jr Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nabi Jr Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift motherboard to separate it the from the case shell.
Kaila Joy
crwdns2935283:003/24/15crwdne2935283:0
86 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 crwdns2935289:0UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015crwdne2935289:0
UMASSD-VIJAYBHASKAR-S15S4G3
crwdns2942667:0crwdne2942667:0 1,223
