Nabi Jr Battery Replacement
crwdns2869540:0crwdne2869540:0: 13K
19
97
12,692
crwdns2955950:0crwdne2955950:0: 7
crwdns2960008:07crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 20 - 40 crwdns2931279:0crwdne2931279:0
    1. Nabi Jr Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the red rubber case from the device. This should come off with ease.
    2. Nabi Jr Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
    3. Nabi Jr Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
    4. Nabi Jr Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After loosening the back cover, remove it from the device so you can get at the innards.
    1. Nabi Jr Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the battery up from the motherboard.
      • Don't rip the soldered wires from the board.
      • The battery is stuck to the motherboard with adhesive, it may take a little pull to separate.
    2. Nabi Jr Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the motherboard
      • De-solder the colored wires
      • Be sure to note the order in which the wires are connected to the board before desoldering them.
      • Be careful while removing the solder off of the colored battery wires. The soldering iron will be extremely hot
    3. Nabi Jr Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nabi Jr Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Replace the old battery with the new one
      • Solder the wires of the new battery into the pads on the motherboard
      • Be careful when soldering the wires in. Soldering iron will be extremely hot
    4. Nabi Jr Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the wires are fully soldered, put the new battery back to the initial position
      • Close the case by putting the back cover back on the device
      • Will take some force
      • Make sure the battery is not in the way of the back cover
    5. Nabi Jr Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the back cover is on, screw in the four screws that you had taken off in the beginning
      • Put the red rubber casing back on.
If all the steps were followed correctly, the device should be fully closed and ready to go
Jimmy Nguyen
crwdns2935283:003/24/15crwdne2935283:0
271 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 crwdns2935289:0UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015crwdne2935289:0
UMASSD-VIJAYBHASKAR-S15S4G3
crwdns2947412:07crwdne2947412:0
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
Lus Ka - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
darcshadow - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
Dennis Blixt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
Delores Duke - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I buy the battery live in Mexico
Roos - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 97
crwdns2959996:0crwdne2959996:0 12,692
